How good are the hyd on a 2610?
   / How good are the hyd on a 2610? #1
KennethBrown
Central Texas-Freestone/Donie
Mahindra 5500
My dad has a 2610 yanny and wants to hook up a 3pt log splitter. This sp;itter runs off of the tractors hyd. I don't think it'll be enough to do what he wants? I know there are a ton of variables ( how much psi and volume does trac have vs what does the splitter need) but unfortunetly I have no clue to the answer. Was wondering if anyone has done this before and how well did it work.
   / How good are the hyd on a 2610? #2
I've seen log splitters on much smaller tractors and they work fine. There should be no problems with this one.
Eugene
   / How good are the hyd on a 2610? #3
generally speaking, it depends on the gpm (gallons per minute) that the hydra system will put out which determines the return speed of the splitter. There are also wood splitters that attach to the the PTO / 3pt hitch which will drive the pump off of the pto, this is maybe a better solution for smaller tractors where the hydra pump is taxed enough already ? good luck.
   / How good are the hyd on a 2610? #4
The 2610 is not a small tractor.
Eugene
   / How good are the hyd on a 2610? #5
Eugene
sure, but what's important is the gpm of the pump, and what is the force of the ram cylinder on the splitter. Like if it's a 30ton ram, and the pump is only 12 gpm, the return speed will be slow..
do we know the gpm of the pump in the tractor and the size of the ram cylinder? that's important stuff to know wrt performance of the overall solution..
   / How good are the hyd on a 2610? #6
5.9 gpm at 2500 rpm.
Eugene
2025 SDLANCH SDLD25 UNUSED Crawler Dumper (A53117)
2025 SDLANCH...
2000 TRAILKING TK110HDG-513 LOWBOY TRAILER (A50459)
2000 TRAILKING...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
42013 (A51691)
42013 (A51691)
2018 FORD F-550XL SERVICE TRUCK (A51406)
2018 FORD F-550XL...
Dry Gel Hydration Unit (A53843)
Dry Gel Hydration...
