How heavy/stiff is your clutch pedal?
   / How heavy/stiff is your clutch pedal? #1
Jay4200
Veteran Member
Hudson/Weare, NH
L4200GST w/ LA680 & BX2200D w/ LA211
My L4200GST clutch pedal is pretty stiff - depressing the clutch is definately a "whole leg" operation (like doing a leg press), as opposed to a 'pivot from the ankle' poke the pedal thing, like when driving a car. I had to move my seat up a couple of notches so I had a good platform to push against. It's WAY heavier than a typical car clutch pedal, that's for sure. I'm wondering if this is normal, or if I need to investigate the linkage for corrosion, lack of lube, or something similar.
Thanks - Jay
   / How heavy/stiff is your clutch pedal? #2
I'd bet it's normal. I have a small Mitsubishi and it works fairly easy, though it's a bit tougher than a typical car pedal. I have a buddy with a larger Ford tractor. His clutch will wear out my left leg if I work it long. What you're likely feeling is the spring tension in the clutch pressure plate which squeezes the clutch disc to the flywheel. The more pressure that is applied, the less likely for the clutch to slip. Bigger tractors put out more torque, and consequently need more pressure in the pressure plate. Your leg has to overcome this spring pressure.
Heh, just work out more, or better yet, ride the tractor more and put in for field goal kicker with your favorite NFL team.
Tom
   / How heavy/stiff is your clutch pedal? #3
My L2800HST is just as easy as my 15hp mitsubishi gear, so the question is how long have you owned this tractor and has it been this stiff the whole time you have owned it??
   / How heavy/stiff is your clutch pedal? #4
My M9000 clutch is pretty stiff.
Eric
   / How heavy/stiff is your clutch pedal? #6
I am will to bet so to speak that the previous owner didn't use the clutch hardly ever since it is a Glide shift. If that is right, then the cable is corroded and needs something done to it.
   / How heavy/stiff is your clutch pedal? #7
When using my L4400 for intensive loader work it is my knee that gets sore, not my ankle. So yes, its pretty stiff.
2007 IC Corporation PB105 School Bus (A55852)
2007 IC...
JI Case 1800 3pt 9 Shank Chisel Plow (A50775)
JI Case 1800 3pt 9...
2842 (A54756)
2842 (A54756)
2000 GMC C6500 20ft Rollback Truck (A55788)
2000 GMC C6500...
JOHN DEERE 1705/6700 LOT NUMBER 20 (A53084)
JOHN DEERE...
2016 Godwin CD150M 6in Dri-Prime Pump S/A Trailer (A55851)
2016 Godwin CD150M...
