How many hours...
   / How many hours... #1
Kenneth in Texas
Pretty good ways from DFW, Texas
Kubota L2800 4wd, FEL
Will kubota engines generally go before needing an overhaul providing they are maintained according to the book? Mine just turned over 450 and it seems like its runs as good as the day i got it. How many hours do you have on yours?
   / How many hours... #2
I had 1,353 hours on my L3830 when I traded it recently. The engine was running like the day I purchased it new. I serviced it as shown in the Owner's Manual using Kubota filters and fluids. With proper maintenance, I don't think engine longevity is a real concern.
Bill
   / How many hours... #3
450 is barely broken in, by diesel standards. I would expect you to get well in excess of 5000 hours, maybe twice that if it was used for long periods under load. Idling and frequent start-stop cycles are hard on engines. One of the large diesel manufacturers estimates each start is equivalent to 20 running hours worth of wear and tear.
   / How many hours... #4
450 hours is just a starting point. Decent diesel engines should get 4-6000 hours or more before needing an overhaul and Kubota makes excellent engines. I don't think I've ever heard of anyone having to overhaul an engine here on the board.
I can tell you that for tracked skid steers, they usually need undercarriage overhaul at 2-3000 hours but I don't hear people needing engine overhauls.
   / How many hours... #5
Clean fuel and clean filters are the life of a diesel. There's a Kubota at work with 3,000+ hours that still runs well. Another does perimeter patrol 24/7 and has more issues with wearing out tires than engine problems.
   / How many hours... #6
I have seen many Kubota engines with 5K - 10+K hours running like new with only prescribed maintenance done on them. On the other hand I have seen the same number or more with engine worn out in under 500 hrs. due no or poor maintenance, or running contaminated fuel.
   / How many hours... #7
I think everything else on your Kubota will wear out before the engine does.
   / How many hours... #8
   / How many hours...
thats good to know. Im amazed at my tractor, its basically just like it was the day i bought it, still tight, still bright orange and does everything i ask of it, never had one single problem, knock on wood.
24in Tractor Backhoe Bucket BT4555 (A50397)
24in Tractor...
New/Unused 20ft Iron Farm Driveway Gate (A48837)
New/Unused 20ft...
New/Unused Quick Attach Pallet Forks (A48837)
New/Unused Quick...
1996 Stoughton Semi-Trailer (A50860)
1996 Stoughton...
2023 PJ 49FT Gooseneck Trailer - 35+5, Mega Ramps, 30,000 GVW, Electric Brakes (A50397)
2023 PJ 49FT...
1999 Freightliner FL70 Truck, VIN # 1FV6HJAA0XHB19718 (A48836)
1999 Freightliner...
