How many rear remotes?
   / How many rear remotes? #1
rickmacheske
Catharpin, VA
Kubota L3400 HST
I'm about to buy a rear remote for my 'bota. I want to make sure that I get maximum flexibility to use the remotes for any toys...I mean tools...that I decide to get later. I've been told by the dealer that I would never use more than 1 valve. How many would I need if I wanted a 3pt backhoe? Any reason to have more than 2?
Thanks for the help.
Rick
   / How many rear remotes? #2
Rick if it were me I would get at least 2 rear remotes if you can swing it. That way you can add Top & Tilt at a later time if you wish. Get the tractor set up for power beyond to power the BH.
That's what I was thinking as well. A second only will cost me an extra $250 for a Kubota valve. My guess is that the dealer didn't have the stackable valves in stock. I asked about power beyond for the L3400. The dealer said that I would need to replace the existing hydralic valve with a different one to do that. I think he was talking about a grand series valve.
I wonder if that's the only way to add a backhoe to a L3400. Oh, I guess I could get one of the 'hoes that have independant hydraulics fed by the PTO.
   / How many rear remotes? #4
I have three on the L4330 installed for the box blade...Top..Tilt..and the Scarifiers.
The Top and Tilt are very usefull. I am not sure about the third for the scarifiers. I got all three installed with the original tractor purchase in part because I am a newbie and didn't want to instal them myself at a later date.
If I were an experienced user perhaps I could do with less. I am learning by experimenting. It would take a lot of time constantly jumping off the tractor to make adjustments on the box blade.
Zeuspaul
   / How many rear remotes? #5
I have one set on my New Holland TC30 and whish that I had at least one more. If you can get a second set that cheap than I would go for it if you have the money. You won't regret it.
Daryle.
Two is winning hands down. Guess that makes it easy.
   / How many rear remotes? #7
I have 3 on my L3130 Kubota. An attachment that I have for my loader requires 2 valves for control when in use plus I wanted control of the top link at the same time. I admit that most of the time I have only 2 valves in use, top link and grapple on bucket.
I don't have tilt but will probably add it one day and I already have the capability to use it.
Vernon
   / How many rear remotes? #8
I think its like attachments(more is better). I had one and then found I needed two so I added a second set with a selector valve. I use both fairly often. The selector valve is a little cumbersome, but works o.k. I would have preferred two separate sets, but they weren't available for my tractor. There are times when I could use three, but I can live without the third one.
   / How many rear remotes? #9
I have three on mine. I have TNT which uses two of the three. I'm toying with adding a grapple which would use the third. In the winter, I take off the tilt cylinder and put on my snowblower which has hydraulic chute rotation and a hydraulic chute deflector. I leave the HTL on so I'm using all three all winter.
   / How many rear remotes? #10
I went with 3 on our tractor. TNT use 2 & the other is for whatever comes up. It was used this spring for the hay rake cylinder.
Pallet of (8) 10 Lug Misc Wheels (A51573)
Pallet of (8) 10...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
7022 (A50322)
7022 (A50322)
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50323)
BW RVB3405...
2022 Wacker Neuson SM100 Mini Skid Steer (A53472)
2022 Wacker Neuson...
2019 Doosan LCV6W Towable LED Light Tower (A51691)
2019 Doosan LCV6W...
