how much do wheel weights weigh?
   / how much do wheel weights weigh? #1
jnh92
Converse, TX
2008 JD 3320
I was wanting to add some weight to my JD3320 on the rear so when I use my forks, so I could remove my shredder. I've seen the ballast box, however I was wondering about wheel weights or those suitcase type front weights. Does anyone know how much either the wheel weigths or the front weights weigh?
   / how much do wheel weights weigh? #2
Just look up your tractor on the "Build your own" section at Deere.com you can get prices weight and part numbers in one place.
   / how much do wheel weights weigh? #3
The front weights are 42 lbs a piece, and cost about $1 per pound. Not sure what the wheel weights way...
But, wheel weights alone will not be enough weight unless your tires are filled. I personally like the ballast box filled with Portland cement, it's a fast (especially with the iMatch QH), compact way to add 1000lbs to the rear of your machine. Your loader manual list specifics on how to ballast your machine properly.
   / how much do wheel weights weigh? #4
Your tire style / size will dictate what wheel weights it can accept. If it is the r4 industrial style (15-19.5) they are 55#'s both for starter and add on weight $2.00 / lb is the norm for that particular weight. If it is r1 ag tires (24" wheels) then they are the 110# weights for starter and add on and these will be closer to the $1.00 + / lb.
55# bm17968
110# t19293
thanks for the info!
Guard Rail Joints (A51692)
Guard Rail Joints...
2012 LEEBOY 8515B APHALT PAVER (A51406)
2012 LEEBOY 8515B...
198367 (A51243)
198367 (A51243)
2016 Ford F550 4x4 Bucket Truck with Altec AT41 - 46FT Rotating Bucket and Jib Winch (A52748)
2016 Ford F550 4x4...
2005 Superior Trailers VT130 T/A Vacuum Trailer (A51692)
2005 Superior...
