How much do you till and with what
   / How much do you till and with what #1
Jnasystems
Waukesha Co, WI
1986 Ford/NH 1520, 1950 Allis Chalmers WD, 2001 NH EC35 (track hoe)
I have about 3.5 acres I would like to put corn and pumpkins on and would like some ideas on how to till and plant it. Currently I have two tractors that could be used - a 1950 Allis WD (it has about 35 hp and a snap coupler hitch) and a Ford 1520 (23hp engine 18hp pto I think). The Allis came with a 3 bottom plow for the snap coupler, but I am not sure the Allis can pull it - I tried, but the area needs to have small stumps removed and I don't feel it was fair either way. What do you use at your place? Would this be too much for a rotary tiller?
   / How much do you till and with what #2
My soil is fairly thin gravely loam (good stuff is about 6 inches thick). So I till it with an old 6.5 ft wide Towner offset disc and my 2008 Mahindra 5525 (54 hp engine, 45 hp pto, 2WD, power steering, gear tranny 8F/2R). Plant oat hay in Oct/Nov, cut and bale in May. Don't use a moldboard plow since that type of plow flips the soil. In my case a moldboard would just bury what good soil I have and bring the bad stuff to the surface.
How large an area are you working?
   / How much do you till and with what #4
A 60" tiller with a 35hp tractor should be able to till this in 5 hours at about 1.2mph. I don't think a WD has a 3ph to match to a tiller though.
The cheapest way to do it is have someone with a larger tractor disc, or till it for you the first time. I would think you could till with a 48" tiller behind the Ford in subsequent years. I would till up the rows for planting and seeding.
   / How much do you till and with what #5
save time and money,..Disc as deep as you can once, or twice and then run the tiller, or just mallbord plow it
   / How much do you till and with what #6
i don't think a rotary tiller will deal with the small stumps very well. i would plow it and disk it.
   / How much do you till and with what #7
I like to turn it over with a plow, disc it and finsih with a drag harrow.
   / How much do you till and with what #8
Ok - this is apparently a new area for you. My first inclination would be to get as many stumps and roots out as I could so as not to damage my tillage equipment. I now have my garden clear of such things which makes it very easy to work. A backhoe could probably be used to dig the stumps out. I used a stump grinding service to remove a large stump. Since my plot had never been used as a garden I plowed to break up the hard pan and pulled out roots at the same time.
I tilled with a 48" tiller until the soil worked very easy. Before tilling now I plow up or pull out all the old plants to get rid of any disease that may have crept in. I then till thoroughly followed by spreading fertilizer. I do raised bed gardening. I have a toolbar with two 16" discs set at sharp angles to push the tilled soil into a bed. That's the method that I have developed during the 4 seasons I have been gardening.
Cheers
   / How much do you till and with what #9
I've cleared and de-stumped almost every inch of my food plot land. I grind my stumps out with a woods 3-point grinder on my tractor....and use various implements to clear the land. I have a landscape rake and a root grapple on my loader.
For tillage I do NOT use a moldboard plow.....as in my case I only have a few inches of good quality soil. I tried a plow early on....and found that a turning plow will bring up sand and bury my better sandy-loam soil. I typically make a few passes with a disc to insure I got all the stumps and rocks out......
Thereafter......I use a 60" King Kutter tiller with my 26PTO HP tractor. I have a JD 3320 tractor. I till about 5 to 8 acres each year. Depending on crops and rotation etc. I can till about an acre per hour.
Wow, a lot of good info!! You are correct, I haven't done this before and wasn't sure a tiller made sense for that much land, but it seems it should be more than able to do the job. I do have a 3 bottom plow for an Allis Chalmers, but not sure if mine has what it takes to pull it. That being said, that and a middle buster is all the tillage equipment I have.
Based on the above info and what I currently think, here is my plan:
1. Build a bar for 5 scarifiers to be mounted on my track hoe and rip out all the stumps and rocks.
2. Buy a good subsoiler and run that over the entire plot with about a 2ft spacing.
3. Till with a 60" tiller nice and slow using the Ford.
4. Plant with a 2 row planter
I after that, I figured I could spray some kind of weed and feed via my sprayer mounted to a 4wheeler and pick by hand. Really what I want is to have hay rides through the woods to the pumpkin patch and a small corn maze. Does this sound like it could work? What changes should I make to the plan?
2016 Ford F-750 14FT Flatbed Truck (A52377)
2016 Ford F-750...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
2010 HEIL TOKEN TRAILER (A53843)
2010 HEIL TOKEN...
2013 Cadillac ATS Sedan (A53424)
2013 Cadillac ATS...
2023 CATERPILLAR 299D3 XE SKID STEER (A52705)
2023 CATERPILLAR...
JOHN DEERE 408R (A53084)
JOHN DEERE 408R...
