How much PTO shaft overlap is safe - slightly different issue
   / How much PTO shaft overlap is safe - slightly different issue #1
davesalisbury
Xenia, OH
Kubota B2630
Hi all-
Long story for setup...
I have about 3 acres of "non lawn" that I'd like to hit about 2X per year. Just hitting it with a bush hog means it looks ropy (it gets pretty tall). I found a sickle bar mower (one of the old IH models with a rear wheel and a bar across the front, apparently designed for a Farmall-type mount) for $DIRT cheap (everything looks good so it should work), took the bar off, put on 3PH pins, bolted a chain on to lift the top and it works with my quick hitch (as an aside, HOW did I EVER live without the QH?). This would allow less frequent cuts, yet leave the field looking a little better (before anybody asks, nobody seems to want to simply mow it in exchange for taking the hay that I could find :confused: ).
Unfortunately, the PTO as designed is too short to reach on my B2630 (even without the quick hitch). Each 1/2 of the shaft is about 9.5 inches (13 inches after a minimum safe overlap), and the reach now needs to be more like 39 inches. The shaft pieces are rectangular, with the big side being 1 1/4" by 1 3/8", and the smaller side being 1" X 1 1/8".
I have two ideas...
First is to simply buy a longer "big side" (enough to overlap by 6" leaving 3 1/2" for slack) and swap out the bigger side. Would probably need a machinist (I could probably do this but lack the tools). This would make the overlap asymetrical, so I guess that's question 1. Would this be acceptable/safe?
Second is a bit more complicated, but should mean a more symmetrical overlap if I'm thinking right. Buy a tube the size of the big tube, then let it overlap the smaller tube by 6 inches). Buy a tube the size of the smaller tube, then have that welded that to the "new" big tube after overlapping 6 inches inside that. It'd then stick into the "old" big tube by at least 6 inches. In essence, there'd be two overlap points rather than a single one. This way I have the mower in original condition should one of those old IH Farmall types want to buy it for a price that'd let me get a regular 3PH mower :)laughing:). Is there anything inherently dumb about this idea (besides the resale plan)?
As always, good ideas, ill-informed speculation and evaluation of my ideas are welcome and indeed encouraged.
Best,
Dave
   / How much PTO shaft overlap is safe - slightly different issue #3
My paperwork said "check for 4 inch overlap" it is about 3 inches, So?.
2023 JOHN DEERE 8R370 LOT IDENTIFIER 204 (A53084)
2023 JOHN DEERE...
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
JOHN DEERE 5075GN LOT IDENTIFIER 115 (A53084)
JOHN DEERE 5075GN...
2021 KUBOTA SVL75-2 SKID STEER (A51246)
2021 KUBOTA...
2024 JOHN DEERE 324G LOT IDENTIFIER 250 (A53084)
2024 JOHN DEERE...
2020 Featherlite Aluminum Stock Trailer (A52384)
2020 Featherlite...
