How often do you change your brush hog blades or ever?
   / How often do you change your brush hog blades or ever? #1
sweep
Ohio hill country
2006 TC45A
My bought new brush hog has been used for 5 years now and the cut does not seem as crisp as when new or what I remember whan it was new. Have been BH approx 9 acres every several weeks spring summer and early fall.
Can these blades be sharpened or just replaced? If I recall they were not real sharp to begin with and from what I have read are not supposed to be real sharp anyway as a sharp blade will create pungy sticks with sapplings.
Am I getting to the point they need replaced based upon what I have used them for so far or am I just imagining the cut is not as good??
   / How often do you change your brush hog blades or ever? #2
Bush hog blades are not supposed to be knife edge sharp but rather blunt but not rounded...you can take a grinder and raise your bush hog...put supports under it for your safety and then wearing gloves hold each blade and put a square edge back on them..You might find a picture on the internet or go to Tractor Supply to look at a new blade and get an idea of what the edge is supposed to look like...it is flat.and the ends of the blade should be ground square...that is what I do..see what others have to say.
   / How often do you change your brush hog blades or ever? #3
They should be sharpened as per use.
if you cut alot.. inspect them alot.
for the average user, a sharpening every spring before use is good enough. remember that you only need to sharpen them down to about a 1/16 blunt edge. this helps them survive rock hits better and also tends to shatter brush instead of cutitng them into sharp punji sticks that poke holes in tires. shattered brush dies faster than a clean cut.
replacement? as needed.. unless you are mowing lots of boulders, and are doing just regular cutting.. I can sure see 20ys on a set of blades.
if you find rock nicks.. just dress them with a file.
inspect for cracks or missing pieces. cracks or missing pieces.. repalce immediatly.
soundguy
   / How often do you change your brush hog blades or ever? #4
Pretty much what everyone else said, take it back to the original profile and do not round the ends.
Thanks for the info
I grease the u joints, rear wheel, pivot, safety cover etc every 8 hours.
I have never greased the expandable slip shaft on the drive shaft ever. Never thought about it to be honest. I'm going to unhook the shaft from the pto tonight and pull it apart and grease it.
Do you all grease this part of the shaft??
My dealer said you would be surprised how many only grease their u joints etc every couple months or even once a season on their brush hogs.
   / How often do you change your brush hog blades or ever? #6
yes.. the drive shaft needs grease. my jd driveshafts have grease tittings half way down the shaft even.
soundguy
HEADACHE RACK (A47001)
New Holland 450 Sickle Bar Mower (A47809)
New Holland 450...
New Holland 273 Small Square Baler (A47809)
New Holland 273...
2015 Chevrolet Caprice Sedan (A46684)
2015 Chevrolet...
2005 Deere 310G (A46443)
2005 Deere 310G...
24 CENTRAL FABRICATORS BUCKET (A47001)
24 CENTRAL...
