How old is the hydraulic fluid
   / How old is the hydraulic fluid #1
Edmund
Kubota M5400
I recently bought a Kubota M5400 with 1100 hours. Is there a way to tell how old the hydraulic fluid is? I know that I should assume that it needs changing. However it looks clear as glass. I hate to throw it away for nothing. The filters are not new.
   / How old is the hydraulic fluid #2
I would check with a Dealer I know that fluid can be analyzed. I Have no idea of the cost though.
I have never seen used hydraulic fluid look anything but new on a machine even when it is time for a change. Kind of the nature of the use. I guess if you had a serious problem like water or air it would show up by looking at it but for just used I doubt very much it will look much different than new.
   / How old is the hydraulic fluid #3
When I buy a used machine I figure to pull a complete PM unless the dealer can prove when it was last serviced. Oil, filters & grease are cheap compared to repairs.
   / How old is the hydraulic fluid #4
My experience with hydraulic fluid is that it always looks clean. Don't take a chance on it. Change it unless you have documents stating it was changed at such and such a time.
just my opinion.
murph
   / How old is the hydraulic fluid #5
Blackstone Labs does oil analysis. You can send them an oil sample from your engine as well. Their tests will let you know if there are any internal problems or possible concerns. Well worth the $20 bucks. As for the hydraulic fluid I'd probably just change it and the filter just so YOU know what's in it and when it was last changed for sure.
   / How old is the hydraulic fluid #6
The fact that the filters are old would be reason enough for me to change the oil. You have no idea whether the previous owner went cheap and put straight hydraulic jack oil in ( clear ) or paid twice as much for the correct universal transdraulic oil... much of which is light honey colored...
Get rid of the old filters... I'll bet the filters cost more than a 5 gallon pail of oil anyway.... They do on my NH.
Soundguy
   / How old is the hydraulic fluid #7
It makes great bar oil for a chainsaw. So in a sense your would be recycling it.
   / How old is the hydraulic fluid #8
I've been usin' recycled vegtable oil on my chainsaw, figurin' it'll break down in the enviornment. Don't cost nothin' either. /forums/images/graemlins/wink.gif
   / How old is the hydraulic fluid #9
</font><font color="blue" class="small">( I've been usin' recycled vegtable oil on my chainsaw )</font>
...so when you're out there cuttin' firewood, does your chainsaw smell like french fries when it gets hot? /forums/images/graemlins/laugh.gif
   / How old is the hydraulic fluid #10
If it doesn't look milky then it probably is fine to use. I would pick a time when the weather is consistant and condisation would not be a consideration and change it and filters then.
Yamaha Jetski With Trailer (A47484)
Yamaha Jetski With...
Great Plains 3P300 Three point Hitch Mounted Sprayer (A46877)
Great Plains 3P300...
Adams 8 Ton Weigh Hopper (A46877)
Adams 8 Ton Weigh...
Front Weights & Spacers for international 5088 (A47484)
Front Weights &...
Trash Combo Trailer (A45336)
Trash Combo...
2000 Gallon Nurse Tank on Semi Pup Trailer (A47369)
2000 Gallon Nurse...
