How to add oil to 400 Farmall
   / How to add oil to 400 Farmall #1
Howie54
Hi, i'am new to restoring Tractors.I'am having problems getting oil in my tractor,there is a small fitting on the rear of the valve cover,but the hole in it is so small it will take a funnel with a very small end to get the oil in it.The second problem i can't get the fitting out of the valve cover.Does anyone have any suggestions or has anyone run in to this problem? The Tractor is a 400 Farmall.
   / How to add oil to 400 Farmall #2
Howie54
Welcome to TBN. /forums/images/graemlins/smile.gif
I had a Farmall 340 and have used several other models over the years. There is usually a 3" vent cap on the side of the engine block. The vent may be rusted onto the tube that is in the block.
Hope this helps.
PICKUP TIRE CHAINS (A50854)
PICKUP TIRE CHAINS...
2013 Ford Econoline E350 Passenger Van (A49461)
2013 Ford...
2022 Ford F-550 Cab and Chassis Truck (A50323)
2022 Ford F-550...
2021 New Holland C327 Compact Track Loader (A51039)
2021 New Holland...
JLG 1255 Telehandler (A51039)
JLG 1255...
4 1/2 150G DRILL STEM 288 JOINTS (A50854)
4 1/2 150G DRILL...
