how to bleed air out of fuel line on a John Deere 5210, no hand pump
   / how to bleed air out of fuel line on a John Deere 5210, no hand pump #1
blach57
Colleyville , Texas
John Deere tractor 5210
how do I bleed the air out of fuel line on John Deer 5210 with no hand pump on the injector pump?
   / how to bleed air out of fuel line on a John Deere 5210, no hand pump #3
If I have trouble get hand pump to pump fuel of tractor has no hand pump I CAREFULLY squirt compressed air into the fuel tank filler neck while using a rag to contain the air to force fuel out the loosened bleeder opening.
   / how to bleed air out of fuel line on a John Deere 5210, no hand pump #5
I've faced the same issue. the most detiled information regarding 5210 john deere you can find here.
I have this manual already. Let me know if you need it.
   / how to bleed air out of fuel line on a John Deere 5210, no hand pump #6
That note about having the fuel tank full is important. It helps bring the fuel down to the filter and hand pump.
I don't like that on my 5045 the fuel filter is on the right side of the engine and the injector pump on the left. You can't pump the priming pump and observe the bleed screw for bubbles at the same time. PITA if your by yourself.
2015 John Deere 4x2 TX Gator (A50121)
2015 John Deere...
2019 Kubota RTVX1140 (A50121)
2019 Kubota...
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tactor (A50323)
2009 Peterbilt 384...
2018 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A52576)
2018 FREIGHTLINER...
2015 Deere 204K (A50120)
2015 Deere 204K...
2019 CHEVROLET SILVERADO 1500 (A52472)
2019 CHEVROLET...
