How to calculate Hydraulic Hose Size when designing a system
   / How to calculate Hydraulic Hose Size when designing a system #1
drfang
New Zealand
Ferguson
Is 5/16 ID hose sufficient on a logsplitter running at 3000psi and 16gpm pump , a 4inch ID ram 9hp honda motor. It seems smaller than usual but how will it affect speed and pressure at the ram if at all please?
   / How to calculate Hydraulic Hose Size when designing a system #2
For that, you would an hydraulic hose flow rate chart. This will give you all the info you need to choose the right hose.
Here is an example. You have the GPM on the left, the recommended velocity of the fluid on the right. Connecting both with a line, will give you the proper hose size on the middle.
5/16" is way too small. This would most likely cause the pump to constantly go in the low volume-high pressure mode because of all the restriction of the small hose and fittings.
For 16GPM, you could go with 1/2", although is right on the edge of it. 5/8" would probably be the ideal one.
Three Key Words in Hydraulic Hose Sizing: I.D., Dash Size and Nomogram
   / How to calculate Hydraulic Hose Size when designing a system #3
5/16 is WAAAAYYYYY too small for 16gpm. Its only good for about 5-6 gpm
This is interactive. But I usually can only get it to work on a desktop, but its been awhile since I have tried from a mobile device
   / How to calculate Hydraulic Hose Size when designing a system #4
The basic way to size hose for a hydraulic pump is to match pump outlet size minimum or one size larger. Also check hydraulic fitting as some styles or brands are restrictive.
Many Thanks. I'm overwhelmed by the response All good stuff and it has helped confirm my suspicion that I was not getting good advice locally!
2005 Ford F150 XL Triton (A50120)
2005 Ford F150 XL...
GOODYEAR SET OF 9.5-24 AG TIRES (NEW) (A52748)
GOODYEAR SET OF...
2008 Ford E-250 Cargo Van (A50323)
2008 Ford E-250...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2011 Liebherr L586 (A52748)
2011 Liebherr L586...
2012 John Deere Gator HPX 4x4 Utility Cart (A51691)
2012 John Deere...
