How to cut through BIG tree roots?
   / How to cut through BIG tree roots? #1
familyman
Platinum Member
Perkiomenville, Pa
Kubota L3800HST
I once had a manufacturers website on my favorites list who made a sharp edged ripper attachment for backhoe buckets (the link is gone - victim of crashosis). The stump I started digging today has some roots 3-4" in diameter 24" out from the stump, and although I'd eventually get it done, digging this one this is hard on my machine. Does anyone know of a product that mounts to a backhoe bucket, dipper stick, or even the 3-pt. for cutting through roots? TSC has a subsoiler for about $160 that I guess I could sharpen, but I'm not sure it would work.
   / How to cut through BIG tree roots? #3
I have the sub soiler from TSC, and I do not think it would work.......
I thought about the chainsaw, but the roots are at various depths, so far 6" to 12" deep, around the stump. It may be my only recourse.
   / How to cut through BIG tree roots? #5
Soil will ruin a chain and wear you out trying to keep it sharp (already ruined).
   / How to cut through BIG tree roots? #7
Harbor Freight has a chaiin saw sharpener for about $40 on sale at the moment... I have one.... works fine.... Ii'd get a couple of chains, dig as much dirt as possiible, chain saw carefully, resharpen when necessary... can't thiink of another way... assumiing you can't get a chain under the root and pull it out of the ground...
   / How to cut through BIG tree roots? #8
Could you sharpen one or both sides of the bucket, or bolt on some blades; especially if you had a thumb, this would almost have to do something...
Mike
   / How to cut through BIG tree roots? #9
What about a scarifier tooth (like in a box blade). Might have to fab up some way to pin it to your bucket, or bucket attachment. Then you need some way to sharpen it. Maybe that would cut through your roots.
   / How to cut through BIG tree roots? #10
If you have access to water, dig around the stumps and then use a strong blast of water to clear off any dirt and rocks around the roots before cutting them.
Heck, if you have a pressure washer and a trash pump, you could keep digging and cleaning and then pump out the slurry. Pretty messy, though...
2008 Fisher 180 Pontoon Boat and Trailer (A44391)
2008 Fisher 180...
1995 Ford F-250 Pickup Truck, VIN # 2FTHF26H8SCA72926 (A44391)
1995 Ford F-250...
JLG 16ft 6,500lb T/A Lo Riser Flatbed Trailer (A44571)
JLG 16ft 6,500lb...
40ft 5 Dual Door Shipping Container (A44571)
40ft 5 Dual Door...
2015 Ford Explorer Multipurpose Vehicle (MPV), VIN # 1FM5K7B95FGC07547 (A44391)
2015 Ford Explorer...
2007 Ford Crown Victoria (A45336)
2007 Ford Crown...
