How to fasten to a straight crankshaft
   / How to fasten to a straight crankshaft #1
jeffscoggins
Brainerd, MN
Melroe 610
I've got a bobcat 610 that has been converted to a Honda engine, which has a straight crankshaft rather than a tapered one like the old Wisconsin engine had. I'm having a terrible time keeping it tight to the shaft. No matter what I do it works loose and begins flopping on the shaft. There's a brass bushing inside the sheave to adapt it down to fit the shaft and there are two set screws intended to tighten against the shaft to hold it tight. But it doesn't seem to hold it. Any ideas?
   / How to fasten to a straight crankshaft #2
Try a local industrial supply for a split taper bushing and sheave. If you buy one get installation instructions and follow them to the letter, especially the cap screw torque.
The bushing will look similar to this one linked.
WOODS ST 1 3/16 SPLIT TAPER BUSHING | eBay
RIGID TOOLBOX (A52472)
2016 Ford F-450 Cab and Chassis Truck (A51692)
2016 Ford F-450...
2003 Lincoln LS (A50324)
2003 Lincoln LS...
2015 Ford F-550 Godwin 184U Crew Cab Mason Dump Truck (A51692)
2015 Ford F-550...
2009 Freightliner M2 106 MedTec Ambulance (A51692)
2009 Freightliner...
2008 AAR MOBILITY SYSTEM REFRIGERATED BOX (A52576)
2008 AAR MOBILITY...
