How to I remove the lower pins on the bucket ( Quick connect plate )?
   / How to I remove the lower pins on the bucket ( Quick connect plate )? #1
Fred Bryant
Wenatchee, Wa
Bobcat 763
The bolts on both sides just spin and spin.
Thx's, Fred.
   / How to I remove the lower pins on the bucket ( Quick connect plate )? #2
Hi Fred, A little more info with perhaps a pic or 2 might generate some useable responses.
   / How to I remove the lower pins on the bucket ( Quick connect plate )? #3
The side of the pin with the bolt is tapered. You can try to tightened it first then put a load on the Pim with the bucket then use an impact to remove the bolt. Once the bolt is out you need to remove the grease fitting in the opposite side. The pin gets pushed towards the grease fitting into a cavity on the qa. The cavity is probably filled with old dried grease so some brake fluid will help a lot to het it cleaned out. It will take some work to get enough of the old grease out to get the pin to move far enough.
Horrible design.
Thx's, I will give it a try.
2004 Ferrara Apparatus Pumper Fire Truck (A55852)
2004 Ferrara...
2008 PARKER  25 T/A GOOSENECK (A55745)
2008 PARKER 25...
2019 Chevrolet Cruze Sedan (A53424)
2019 Chevrolet...
2014 COMPTANK  ACID TRANSPORT TRAILER (A55745)
2014 COMPTANK...
2004 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A55745)
2004 DRAGON 150...
2017 FECON RTF140 HIGH PERFORMANCE MULCHER (A52707)
2017 FECON RTF140...
