How to keep 3pt from lifting?
   / How to keep 3pt from lifting? #1
tony123
Platinum Member
Travelers Rest, SC
YMG2000D
I recently got a small utility trailer that we're attaching to a draw bar across the 3pt. However, when we put weight on the back of the trailer it lifts the tongue. Is there a way to lock it so that it doesn't rise like that?
I know the hydrolic flow lock will keep something from dropping, but what about the other direction?
Thanks.
   / How to keep 3pt from lifting? #2
Don't put weight in the back of the trailer. ;)
The 3ph will rise if upward pressure is placed on the lower arms. They are designed that way.
Can you pull from the tractor's frame mounted drawbar instead?
   / How to keep 3pt from lifting? #3
The easiest way it to put a chain from the new draw bar down to the belly draw bar. Bolt it so that it won't come off. You sure don't want the trailer coming up when you get it loaded.
That's a good idea with the chain, thanks.
I can't go straight to the belly draw bar, as it is way too low to keep the trailer level.
   / How to keep 3pt from lifting? #5
Thanks.
Attached is a photo of a 2" receiver hitch that I made for my tractor. The chain is used only with a trailer to keep it from lifting.
   / How to keep 3pt from lifting? #6
That ought to keep 'er down! Nice hitch!
   / How to keep 3pt from lifting? #7
A few folks here posted about one of these, so I added one. It works great!
   / How to keep 3pt from lifting? #8
Kind of hard to use that while your moving the trailer though:D
   / How to keep 3pt from lifting? #9
Correct, but I usually keep my trailer still when I'm loading it. :D Otherwise sort of bad practice I'm told to keep up pressuse on a hitch all the time. :D
Of course the jack flips up when not in use.
   / How to keep 3pt from lifting? #10
I have one of those I welded to the tongue of a little 5x8 tilt trailer. It looks like you have it on the rear of a much larger trailer. I think the jack is only rated at 2,000 lbs.
A buddy of mine did something similar, but he put one on each side. He swears by his.
2021 JOHN DEERE 524P WHEEL LOADER (A52705)
2021 JOHN DEERE...
2015 Kia Cadenza Sedan (A53424)
2015 Kia Cadenza...
Adams 5T High Clearance Fertilizer Spreader (A55301)
Adams 5T High...
AUCTION STARTS HERE @ 9AM (A51406)
AUCTION STARTS...
2008 Hitachi PC228 (A47477)
2008 Hitachi PC228...
Utility Trailer (A52377)
Utility Trailer...
