how to measure and cut pto shaft
   / how to measure and cut pto shaft #1
kully
Bronze Member
upper ny,and long island
kubota m4900 with loader
can some tell me the correct way to figure out the proper length of pto shafts . I just lengthen my pto shaft on the wood chipper had to weld new shaft on the yokes for the new tractor .now I need to cut the shaft down ,I know you need both upper and lower measurements , but then what .is there a proper way to do this ,I guess you all know this is one measurement that is not fun to screw up thanks
   / how to measure and cut pto shaft #2
Yes, kully, there's a proper way to do it. But rather than me try to describe it here, just go to Bushhog.com, click on "Owners Manuals" in the left column, then click on "RTN-RTH-RTNR Rotary Tillers" which will open a .pdf file, page down to page 9 and you'll have both written and illustrated instructions, which apply to other implements as well as tillers.
thanks bird it sure helps ,bush hog has a little better information then my beefco manuel .they both say the shorter length is more imporant so as to not bottom out but also check over lap . well like they say measure twice and cut both sides once thanks for the help kully
   / how to measure and cut pto shaft #4
Thanks for the info Bird. Those directions are much better than what came with the Woods GTC I just bought.
   / how to measure and cut pto shaft #5
</font><font color="blue" class="small">( Thanks for the info Bird. Those directions are much better than what came with the Woods GTC I just bought. )</font>
I got lucky on my Woods GTC shaft. It fit just fine from the start with my Pat's EZ Change system on. Guess I might have had to cut off a little without the Pat's on. John
2015 Infiniti QX60 SUV (A50324)
2015 Infiniti QX60...
1985 Ford Ltl9000 Tender Truck (A52128)
1985 Ford Ltl9000...
2015 DODGE RAM...
TC710 FINISHING MOWER (A50459)
TC710 FINISHING...
2003 PETERBILT PB 330 WATER TRUCK (A51243)
2003 PETERBILT PB...
2012 Case IH Patriot 3330 Self Propelled Sprayer (A50657)
2012 Case IH...
