I bent my Tie Rod and would like to fix it and not buy a new one. I have access to a press like the one attached and also could apply heat via propane torch. I never used a press (or a torch, for that matter
I was going to leave the nut covering the threads on (to help keep it straight) but could the press bend or break the nut? I would like to just bend it without heat, is that possible?
I assume the treads you see on this end are trashed (adjustments with be made on the other end). The red line is what needs to be straight (it has another bend in the tie rod that should be there, I hope
) Any thoughts? I don't need perfection just get it close.
