how to take off blades on kubota mower deck
   / how to take off blades on kubota mower deck #1
nutzer
i own a bx24 60" deck rck60b23bx any help would be great thanks,,,,, nutzer
   / how to take off blades on kubota mower deck #2
Did you get a manual with the deck? The simple instructions are in there. But seeing as how you're asking the question, with any mower you need to block (piece of wood) the blades from spinning when you attach the ratchet wrench to the blade nut/bolt.
You may need a "breaker bar" which can be a short length of pipe slipped over the ratchet handle to help break the nut/bolt. OR...get a hold of an impact driver. Air/battery/electric powered...all will make the job very simple. Just get the correct size socket and zip that nut/bolt off in the wink of an eye...no other doodads needed.
got it, bolt were a little tight,,, thanks for the reply,,,,nutzer
Toro Workman HDX-D Utility Cart (A53421)
Toro Workman HDX-D...
2003 Ferris IS1000 52in Zero Turn Mower (A51694)
2003 Ferris IS1000...
Ammco Brake Machine (A53424)
Ammco Brake...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
2013 PETERBILT 367 HOT OIL UNIT (A53843)
2013 PETERBILT 367...
SDLANCH TRACKED MINI LOADER (A53843)
SDLANCH TRACKED...
