Oil & Fuel HST all weather tractor hydraulic fluid
   / HST all weather tractor hydraulic fluid #1
mx5guy
Carp, Ontario
Kioti CK27 HST
Has any one used this on a Kioti CK 27 HST for 50 hour maintenance?
Pros & Cons would be nice. I have always trusted and had good results with their products.
Product Information
A PRODUCT OF VALVOLINE, A DIVISION OF ASHLAND INC.
VALVOLINE UNITRAC FLUID
Valvoline Unitrac Fluid is a high performance,multi-purpose all-weather fluid designed for agricultural tractors and off-highway equipment. Valvoline Unitrac Fluid is uniquely formulated to provide excellent antiwear, oxidation, ferrous rust and copper corrosion protection. It is designed to reduce wet brake and PTO chatter. This product is recommended for use in the hydraulic systems, final drives, transmissions, differentials, wet brake systems, PTOs and hydrostatic drives.
Meets or exceeds the following current specifications(Where appropriate viscosity grade applies):
John Deere JDM J20C,
New Holland Group(Ford New Holland) FNHA-2-C-201.00(134D), FNHA-2-C-200.00(Hydraulic Oil 134)
Massey Ferguson M1141(PermatranョIII), M1143, M1135
Case Corporation(Case I.H., J.I. Case) MS-1207(Hy-Tranョ Plus), MS-1210/JIC145(TCH Fluid), MS-1230(Poclain Equip.), MS-1209(Hy-Tran Ultra)
Kubota UDT Hydraulic Fluid, Universal Transdraulic Fluid
White Farm(Oliver) Q-1826 Hydraulic, Transmission Fluid HTF)
Agco(Duetz-Allis) Power Fluid 821XL, 272843
Steiger Hydraulic/Transmission Fluid SEMS 17001
Landini Tractor II Hydraulic Fluid; Hesston Fiat Oilofiat Tutela Multi-F
Sundstrand Hydrostactic Transmission Fluid, Hydraulic Fluids
Allison Type C-4 Fluid
Dresser Construction Transmission/Hydraulic Fluid
Denison Hydraulic Fluid HF-0, HF-2, HF-1 All Pumps, Vickers M-2950-S Mobil Hydraulic & I-286-S Industrial Hydraulics
Clark Lift Truck Transmission Fluid TA12, TA18, HR500, HR600
Volvo VME WB 101(97303), ZF TE-ML-03E, TE-ML-05F
Meets or exceeds the following older specifications(Where appropriate viscosity grade applies):
John Deere JDM J20A, J20B, J14B, & JD 303; Ford New Holland ESN-M2C134-C, ESN-M2C134B, ESN-M2C134A, ESN-M2C86B, ESN-M2C53A, ESN-M2C48-B; Massey Ferguson M-1129-A, M-1127-B, M-1127-A, M-1110; Case B-6(HY-TRANョ), MS-1206(PTF), MS-1205, MS-1204/JIC-185, JIC-144, JIC-143, B-5; White Farm(Oliver) Q-1802(Type 55 Fluid), Q-1766B(Universal HTF), Q-1722(White MP Tractor Oil), Q-1705(Universal HTF); Agco(Allis) 257541, 246634; Versatile Hydraulic /Gear Fluid Spec 24M, Spec 23M; Hesston Fiat AF-87; Oliver Q-1802(Type 55), Allison C-3 Fluid; Caterpillar TO-2;
Approvals/Performance Levels
Allis Chalmers PF 821XL
MS-1210
API GL-4
Test
Typical Property
Specific Gravity @ 15.5oF
0.8712
CCS @ -25ーC, cP, max
7000
Brookfield Vis @ -350C, cP
32,000
Vis @ 100ーC (cSt)
9.7
Vis @ 40ーC (cSt)
61.29
Viscosity Index
141
Pour Point ーC
-45
Zn wt%
0.12
This information only applies to products manufactured in the following location(s): USA
Effective Date:
Expiration Date:
Replaces:
Author's Initials:
Pages
Code
11/14/07
04/30/04
Dan Dotson
Rev. 002
   / HST all weather tractor hydraulic fluid #2
I have not used that brand, but I would be fine with it. I have
used lots of Kubota UDT, Chevron 1000 THF, and 76 Tractor Hyd
Fluid. I look for an equivalence rating to UDT or J20C on the label. You
have that. This stuff all looks/smells the same. I see that it may be
starting to be labeled as "GL-4" also, as I see on your spec.
Thanks Dave for your reply, this is my first deisel anything, and have 30 hours on her removing stumps, have good timing on the backhoe, need work on the FEL.:thumbsup:
Larry
2015 Ford F-650 20ft. Flatbed Truck (A48081)
2015 Ford F-650...
2010 Ford Flex Limited SUV (A48082)
2010 Ford Flex...
2007 YANMAR VI027 MINI EXCAVATOR (A50046)
2007 YANMAR VI027...
NORTHSTAR AIR COMPRESSOR (A48992)
NORTHSTAR AIR...
2015 FREIGHTLINER M2 24FT REEFER BOX TRUCK (A50046)
2015 FREIGHTLINER...
2012 INTERNATIONAL MA025 BUCKET TRUCK (A50046)
2012 INTERNATIONAL...
