HST problem in reverse?
   / HST problem in reverse? #1
JKeane
Massey Fergusen MF1758
Hello all,
I own a MF1758 HST tractor that has begun to act strangely when I back up. Seems just fine in forward.
I feel a surging like motion, like I'm backing up over cobbles. Sort of like I feel resistance and then no resistance, if that makes sense. The engine rpm does not fluctuate.
Only about 300 hours on this unit (still a pup), HST fluid is full, running the original R4 rear tires - loaded and inflated to 15 psi. This happens in all three HST ranges.
Any thoughts on this would be appreciated.
Thanks.
John
   / HST problem in reverse? #2
Are you sure the parking brake is released?
   / HST problem in reverse? #3
Under foot plate for build debris build up.
Thanks. Yes, the parking brake is released. However you got me thinking in that direction. I checked and lubed the brake linkage. Didn't see any binding but a little oil can't hurt. I haven't put any time on the tractor since. Plenty of field work coming up soon; I'll let you know if it worked.
Thank you.
Thanks for your response. I crawled under and check for debris. Couldn't see anything. I lubed the brake linkage (as per previous post).
Thank you
   / HST problem in reverse? #6
What kind of tires do you have? I can imagine an aggressive ag tread feeling different going backward.
   / HST problem in reverse? #7
sounds like something is binding in reverse.
   / HST problem in reverse? #8
I have no idea on what type of control is on that HST but possible there is something in the reverse logic causing the surging. Does it do this full speed reverse vs just trying to move slow like inching back to hook something up?
Any unusual sounds or does engine seem to load up a little then unload during the surging?
Tractor has R4 loaded rear tires. Original and in good condition.
I imagine that its possible that something in the reverse logic is causing this issue. Hoping for something more simple. It will surge in reverse at any speed and all ranges. The engine sound and rpm never changes.
Thanks for the input.
INDUSTRIAL SAND BLASTER (A50854)
INDUSTRIAL SAND...
2017 Wacker Neuson ST31 Compact Track Loader Skid Steer (A49461)
2017 Wacker Neuson...
2017 Miller Nitro 6300 Self Propelled Sprayer (A50657)
2017 Miller Nitro...
2016 CATERPILLAR 259D SKID STEER (A50458)
2016 CATERPILLAR...
CUSTOM ALUMINUM 16FT CAR TRAILER (A51222)
CUSTOM ALUMINUM...
NEW 2025 Load Trail 83IN X 14IN Single Axle Utility Trailer (A51039)
NEW 2025 Load...
