ht3813 blades spin but don't cut
   / ht3813 blades spin but don't cut #1
souiam
i have a honda ht3813, the blades spin but it does not cut grass at any level
   / ht3813 blades spin but don't cut #2
Make sure the blades aren't on backwards. The cutting edge has to be in front as it spins.
it was cutting before, then all of sudden just stopped, i think maybe the belt is loose? i tried to tighten the tension but nothing
   / ht3813 blades spin but don't cut #4
Does it have an electric clutch for the deck ?
not sure i think its just a belt though, hoe do i check?
   / ht3813 blades spin but don't cut #6
Look for a pully with wires going to it.
David from jax
   / ht3813 blades spin but don't cut #7
If it is running DON'T try to check it. Kill the engine. If you don't, that will be the first time it will cut. A belt can be so bad that the blades will spin without being loaded but not cut at all. Just be careful with mower blades, and yes, check to see if they are on backwards.
CATERPILLAR CB24B SMOOTH DBL DRUM ROLhttps (A52705)
CATERPILLAR CB24B...
2011 DOOSAN G40 GENERATOR (A53843)
2011 DOOSAN G40...
2004 Sterling Acterra Cab and Chassis S/A Truck (A51692)
2004 Sterling...
HarbinGer Towable Light Tower (A52377)
HarbinGer Towable...
2018 FORREST RIVER CRUISE LITE CAMPER (A52472)
2018 FORREST RIVER...
