Husqvarna Model 55 (15yrs old) taking off clutch/drum to access drive sprocket
   / Husqvarna Model 55 (15yrs old) taking off clutch/drum to access drive sprocket #1
schiker
Anderson, SC (Northwest part of SC)
Ford 3000, 1972 LCG, JD 5603
Are the threads to take off the clutch / drum and access the drive sprocket (they call it a ring) a left handed thread ?
I have the piston stop tool but never taken one off. It seems pretty straight forward take sparkplug out rotate to get piston down or up to approx correct point install stop. Turn slowly until against stop then torque off nut/clutch.
If I am thinking about it correctly the crank is trying to loosen on the nut while cutting. Seems a good candidate for left hand threads. Or is it just a nut and the clutch is keyed to the crank and can't relatively rotate such that left hand threads are not beneficial.
I assume should change needle bearing, clutch drum, and drive ring or sprocket all together.
This is my brother-n-laws saw and I think when the sprocket went the chain chewed on the clutch drum sprocket area a bit. Note I have a model 51 Husky and am letting him borrow my piston stop tool. Thought I'd warn him they might be left hand threads.
   / Husqvarna Model 55 (15yrs old) taking off clutch/drum to access drive sprocket #2
All the saws I have had appart have been left-handed.
But they usually arent super-tight. So if something dont feel right....STOP
   / Husqvarna Model 55 (15yrs old) taking off clutch/drum to access drive sprocket #3
:thumbsup: x2 for LD1
   / Husqvarna Model 55 (15yrs old) taking off clutch/drum to access drive sprocket #4
To remove clutches turn off clockwise. Go back on and tighten counter clock wise. I hope I explained that right to make understanding easier.
WOODS RT48.30 LOT NUMBER 235 (A53084)
WOODS RT48.30 LOT...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
2018 FREIGHTLINER 108SD DUMP TRUCK (A51406)
2018 FREIGHTLINER...
2018 CATERPILLAR 279D SKID STEER (A51246)
2018 CATERPILLAR...
2004 Kenworth T800 Day Cab T/A Truck Tractor (A52377)
2004 Kenworth T800...
43029 (A51691)
43029 (A51691)
