Husqvarna PZT-60 Zero Turn
   / Husqvarna PZT-60 Zero Turn #1
Ninja Rooster
2022 Kioti NS5310
Hello. A zero turn came with the home we bought last year and I’m sure they never maintained it. Less than 200 hours. Used it last summer. This spring I changed the belt, blades, oil and all filters. Runs great. However, noticing leaks and then today while mowing the right side drive started grinding. The longer I went the worse it got. I have to top the 20W50 off every time I use it.
I am assuming my hydro drive on that side needs replaced as I’ve read that is a sign it is worn out.
Agree or have other tips? How difficult are they to replace? Thanks
   / Husqvarna PZT-60 Zero Turn #2
I'd say get underneath anyway and have a look. Rule out the external things first regarding the leak and the noise. 200 hours isn't much. If it comes down to changing it out, you'll see it could very well be a DIY project. Hydro Gear has a good tech support team for questions that you might have and instructions for getting it up and running.
JOHN DEERE 1700 (A53084)
JOHN DEERE 1700...
2013 F-550 Bucket Truck (A53472)
2013 F-550 Bucket...
1993 Mack RD688S Dump Truck, VIN # 2M2P267Y5PC014675 (A51572)
1993 Mack RD688S...
2013 Ford F-450 Dump Truck, VIN # 1FDGW4GY5DEA10351 (A51572)
2013 Ford F-450...
2012 International ProStar Sleeper Cab Truck Tractor (A51692)
2012 International...
2018 SkyJack SJ1056TH 4x4 Rough Terrain Telehandler (A52377)
2018 SkyJack...
