Husvarna Doser Blade
   / Husvarna Doser Blade #1
leeinleetonia
Leetonia, OH
Kubota
I have a 26Hp Husqvarna riding mower and want to use it in the winter for snow removal. They offer a snow blade. Any suggestions?
   / Husvarna Doser Blade #2
I'm no expert but if you have a lot of driveway to clear you might look into a snowblower for your tractor. Snow blade for that
Sent from my iPad using TractorByNet
   / Husvarna Doser Blade #3
I'm no expert but if you have a lot of driveway to clear you might look into a snowblower for your tractor. Snow blade for that tractor will be small
   / Husvarna Doser Blade #4
I'd agree with that. 2wd, wide tires, not much weight doesn't lend itself well to pushing snow. Even with the blower attachment you'll need rear chains and a weight box unless you weigh 350 lbs. A 4x4 ATV does better in most conditions because the plow weighs enough to give the front wheels some bite.
The problem with any plow is finding room to put the snow. Plus you have to drive off the driveway surface to dump the snow, then claw your way back on to it. If you don't, if you get any amount over the winter you'll very quickly run out of places to put it.
The blower allows you to throw it clear off the driveway while still staying on the hard surface. It makes better use of the engine power to do the work and relies less on traction.
My :2cents:
Sean
Thanks, Sean. For the really heavy snow I have two neighbors with Kubota's (4wd) that do the trick. For the lighter stuff (under 4 inch) I used to use a 24hp john deere lawn tractor with a small 42 inch blade that worked (most of the time). Comparing pound for pound, the new Husq weighs about 250 pounds more so traction (with chains) should be better than the former Deere. If life were good, I would just buy a regular 4wd farm tractor and not worry about it. But then, $500 for a blade seems better than $15,000 for a new tractor. If things get really deep, I do have another neighbor up the road with a 145hp john deer and doser blade...
2021 JOHN DEERE CP690 LOT NUMBER 196 (A53084)
2021 JOHN DEERE...
1999 Volvo VN Truck, VIN # 4VG7BBRFXXN772814 (A51572)
1999 Volvo VN...
NEW Skid Steer Bolt on Hay Forks (A53002)
NEW Skid Steer...
6 STEEL KENWORTH T800 BUMPERS (A52472)
6 STEEL KENWORTH...
2013 3400QB SUNDANCE 5TH WHEEL CAMPER (A52472)
2013 3400QB...
2001 Sterling L7500 Heil 12Yd T/A Dump Truck (A51692)
2001 Sterling...
