Hyd. fluid leaking from top of trans?
   / Hyd. fluid leaking from top of trans? #1
10fords
kioti lb2204
On my LB2204 when I have been running the tiller for more than a half hour or so I get hyd. fluid leaking out of the top of the trans. It is not a tremendous amount, but enough to make the pedals and steps slippery! I assume the fluid is expanding as it gets hot? Am I overfilling it or maybe a vent somewhere is blocked? Anyone else have this happen to them? My other tractor (a Kubota L295DT) does the same thing, so is this normal?:confused:
   / Hyd. fluid leaking from top of trans? #2
I would say you have either a clogged breather or you are over filling it. Check sight glass - maybe a plug on the left side transmission.
I filled it to the level of the plug on the side of the trans when I changed fluids last time. Any Idea where the breather is?
48in Forks Loader Attachment (A49346)
48in Forks Loader...
74in FEL HD Round Back Bucket (A51039)
74in FEL HD Round...
2014 Ford F-450 Crew Cab Knapheide Service Truck (A50323)
2014 Ford F-450...
BREWSTER DRAWWORKS WITH TWIN CATERPILLAR ENGINES (A50854)
BREWSTER DRAWWORKS...
2007 TRANSCRAFT 48X102 FLATBED (A50854)
2007 TRANSCRAFT...
WHITE CI-7 DRAW WORKS POWERED BY TWIN (60 SERIES) DETROIT 14.0L ENGINES (A50854)
WHITE CI-7 DRAW...
