Hyd Oil
   / Hyd Oil #1
DougM
Northeast Ohio
GC 2310
I have a CG2310 MF and would like to know Why there is a
sight glass instead of a dip stick??/
Makes no sence to me ??
DougM
   / Hyd Oil #2
Mostlikely a sight glas is on their instead of a dipstick so that the systme is guaranteed sealed. Don't get me wron a dipstick will seal it but a dipstick can be lost or popped off plus to check it you have to wipe it off and put it back in to check it. Not that that's a problem because I don't mind getting my hands dirty, but a sight glass all you have to do is look at it and if the level is ok then you're good to go and you don't have to worry as much about dust and other contaminents getting in from your wiping rag or whatever. Also if you were wanting to check and see if the level dropped off when using your lift or aux. hydraulics you could watch your sight glass.
   / Hyd Oil #3
NOT having a sight glass for my hydro fluid is one of the only things I'd like to change about my Kioti CK20. Every time I pull the dipstick to check the level, I risk contamination that is very easy to enter the dipstick port. A sight glass is a much better option in my opinion. John
   / Hyd Oil #4
I have a sight glass on my L3010 i like it. Most heavy equipment uses them.
2012 Kenworth W900 (HEAVY DUTY) (A52128)
2012 Kenworth W900...
2008 Ford F-350 Altec Service Truck (A50323)
2008 Ford F-350...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
Bobcat 30C Skidloader PHD (A50774)
Bobcat 30C...
3-Point Hitch Root Grubber - Heavy-Duty Tree and Stump Puller for Tractors (A52128)
3-Point Hitch Root...
2015 Kia Sorento AWD SUV (A50324)
2015 Kia Sorento...
