hydralic oil leak
/ hydralic oil leak #1
tim1968
gasport new york
2001 new holland tc25d
my 2001 new holland tc25d is leaking oil down onto the mower deck. oil is coming out a hole that is between front and rear transmission drain plugs.hole is threaded but has no plug in it and i am able to stick a screwdriver into hole several inches, any suggestions? dealer wasnt much help
/ hydralic oil leak #2
is the hole in the dry area of the bellhousing.. aft of engine oil pan but ahead of trans pan? if so it could be a weep hole.. old fords had them.. was to leat oil escape the clutch housing if the rear main or tranny input shaft seals leaked.
it engine oil or utf fluid?
/ hydralic oil leak #4
tranny input shaft seal...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A59904)
2017 FREIGHTLINER...
2023 John Deere 9RX 540 Track Tractor (A63109)
2023 John Deere...
UNUSED KJ 42'X30' METAL STORAGE SHED (A62131)
UNUSED KJ 42'X30'...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2014 John Deere 6125R Tractor (A64047)
2014 John Deere...
2020 Peterbilt 567 Quint Dump (A62613)
2020 Peterbilt 567...
