Hydraulic articulating arm string trimmer?
   / Hydraulic articulating arm string trimmer? #1
hunter63
Kenosha, Wisconsin
Mahindra
I know that that thsi is a dumb question....and being a Noobie, and i suppose I should dig harder on the search........BUT'
Does any one make a articulating arm string trimmer?
Side mount, to reach rocky banks and cut weeds and brush?
Thanks for any info.
   / Hydraulic articulating arm string trimmer? #2
I am looking for exactly that but a lot more substantial than a string trimmer. I need to cut brush - up to 2" buck-brush. I need TPH mount though.
A TPH arangement set up would be alright as well......and I know the make a sidw mount brush hog as they trim the brush along our raod with one....But it's on a big machine not a 3015 Mahindra.
   / Hydraulic articulating arm string trimmer? #4
Tractor Mounted PTO Powered Weed Chopper String Trimmer
Other ideas
4M INC.
Swisher, Swisher Products : 44 Inch Tow-Behind Trailcutter
and
DR DR Power Equipment - Brush Hog / Brush Mower ? clear land / brush - mow saplings make tow-behind mowers that travel beside the tractor but they aren't string trimmers.
I'm been trying to figure out how much hassle it would be to mount a big wheel type string trimmer to a platform that extends out 90 degrees from my forklift forks. Seems trivial to remove the wheels, handle, then bolt the axle to a plank. Would need to create an extension for the throttle and some kind of kill switch.
The top one is kinda what I had in mind, I gonna call them and see it thatr arm can be articulated up and down to trim along a steep bank.
The old side bar mowers might work, but I have a lots of rocks to deal with....
but that is close.
I do have a trail mower that I have basically burned down since 1995, as I used it behing the 4 wheeler for a lot of years before I got the tractor....Not a Swisher, but same deal...still runs but is really beat up....LOL.
Must have broke the tounge off 4 or 5 times
   / Hydraulic articulating arm string trimmer? #7
Google the Swisher Postmaster. It's not exactly what you're after but it might give you some ideas.
   / Hydraulic articulating arm string trimmer? #9
I have an older model 5HP DR trimmer mower that is a beast as a walk behind and the belt keeps triping off from heavy brush limbs. Cuts up to 1" blackberry vines like they are butter. I am toying with a way to mount on the FEL, delete the mickey mouse clutch idler pulley (source of the belt tripping) and replace the motor w/a hydraulic motor powered off the tractor. Would have to work out the speed problem as few HMs run at 3600 RPM like a gas engine. That would be easy to hinge mount and have a posistioning cylinder to angle up and down toget bslopes both up and down. Next winter's project to flesh out.
Any bright guys done this type thing yet?
Ron
2014 Peterbilt 337 Forestry Grapple Truck (A46683)
2014 Peterbilt 337...
2017 Ford Transit 250 Cargo Van (A46683)
2017 Ford Transit...
PENDING SELLER CONFIRMATIONS (A45679)
PENDING SELLER...
Kubota SVL95-2s (A47307)
Kubota SVL95-2s...
2017 Ford F-650 14ft Mason Dump Truck (A46683)
2017 Ford F-650...
2019 CAT 259D3 Tracked Skid Loader (A49339)
2019 CAT 259D3...
