Hydraulic clutch grabbing
   / Hydraulic clutch grabbing #1
gwdixon
Elite Member
Northern CA
There is a lot of good knowledge on TBN about the hydraulic clutch system (hydraulic synchro shuttle) but nothing about a particular issue my M7040 is experiencing.
When manually using the clutch pedal for slipping the clutch the clutch will all of a sudden grab and engage with a jerk. Is there an adjustment that is needed to correct this?
The grab also happens when going over very rough ground where stumps have been removed and clutching is necessary.
As additional information, at times the tractor will creep forward or backward with the shuttle lever in neutral.
I need to pull over large trees that are critical to fall in a certain direction and the jerk is dangerous to the cutter. Slipping the clutch allows the tree to be held with tension until the cut is made.
The tractor is six months old, 170 hrs, and thus is still under warranty.
Thanks.
UNUSED FUTURE SKID STEER QUICK ATTACH SWEEPER (A51244)
UNUSED FUTURE SKID...
Wolverine Mini Skid Steer Combination Bucket (A50514)
Wolverine Mini...
(4) Texas Built 25' Stand Alone Panels (A50515)
(4) Texas Built...
JCB 3TS 8T SKID STEER (A51242)
JCB 3TS 8T SKID...
E-Z Trail 675 Grain Cart (A50514)
E-Z Trail 675...
Kuhns AE10 Small Square Bale Accumulator - 10-Bale Efficient Handling System (A52128)
Kuhns AE10 Small...
