Hydraulic cooler
   / Hydraulic cooler #1
brincker
Mechanicsburg, IL
bobcat CT 230
I have ct230 that is leaking fluid from the hydraulic cooler. anyone know how much it is replace? is it pricey for the dealer to fix it.
   / Hydraulic cooler #2
I assume you are past warranty?
   / Hydraulic cooler #3
Some of the CT's had a history of cooler failures
It would not hurt to ask if Bobcat will stand behind it
   / Hydraulic cooler #4
Welcome to TBN!
Dealer fixes aren't on the cheap side, due to labor rates. What year tractor, how many hours on it, any pics or fuller description of where the leak is? Under warranty or not?
   / Hydraulic cooler #5
If warranty is not an option, you might want to consider trying one of the Kioti dealers (or ordering on line). Michigan Iron has them on their website for $193.55. Its part number T2185-37011.
Link
Many people had problems with them ~3 years ago and there were some old threads here on TBN about the subject. Many were replaced under warranty. Given it's two bolts and two fittings, it should be a pretty easy job to swap one out.
2007 DELTA TRAILER (A52472)
2007 DELTA TRAILER...
Land Honor Skid Steer Winch (A50515)
Land Honor Skid...
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50775)
IF YOU BID ON AN...
2006 Ford Focus Sedan (A51694)
2006 Ford Focus...
2020 Case CX245D SR Excavator (RIDE AND DRIVE) (A50774)
2020 Case CX245D...
