Hydraulic Cyclinder will not retract
   / Hydraulic Cyclinder will not retract #1
rrrjjjfff
Howard, KS
John Deere/5093E
I have a John Deere 5093E that I am using a bale unroller with. The hydraulic cyclinder will open the arms of the bale unroller, but will not retract to close them. Any ideas.
   / Hydraulic Cyclinder will not retract #2
Nut come off the end of the hyd rod in the cyl or stub end broke off??
Control valve issue??
   / Hydraulic Cyclinder will not retract #3
BTW, Welcome to TBN.....:cool2:
   / Hydraulic Cyclinder will not retract #4
Is this tractor new to you? Any other remote you can try. Switch the hoses at the quick connectors. My 4600 Ford has only lift pressure on one of the valves, same as the 3 pt (no down pressure). If I hookup my NH haybine backwards I have very little lift pressure.
Dennis
This is a new tractor and I have tried connecting to different remotes and get the same results.
   / Hydraulic Cyclinder will not retract #6
Do you know if you have flow and or pressure to the cyl or valve?
Install a hyd gage in the first valve IN port in a tee and it will help you with trouble shotng.
Is the cyl a DA cyl, and which valve are you using?
If using QD's, are they connected correctly?
   / Hydraulic Cyclinder will not retract #7
If the pressure is good with a test gauge I would try a different cylinder.Also I would test the hoses to the cylinder. Had a hose collapse inside and it would do that. oil would travel one way but when it returned the broken hose would bloke the flow. Just a suggestion.
2014 Ford Fusion SE Sedan (A53424)
2014 Ford Fusion...
2022 Ford Maverick Crew Cab AWD Pickup Truck (A50323)
2022 Ford Maverick...
2013 Ford F-550 Ext. Cab 4x4 Auto Crane 6406H 6,400LB Crane Service Truck (A53422)
2013 Ford F-550...
2022 JOHN DEERE 331G LOT NUMBER 96 (A53084)
2022 JOHN DEERE...
2017 CASE IH 580 QUADTRAC ARTICULATING TRACTOR (A52705)
2017 CASE IH 580...
