Hydraulic delay circuit
   / Hydraulic delay circuit #1
RPW
Veteran Member
I have a project where I need to extend a cylinder and wait for a lever to trip the retraction of the cylinder. On another circuit I can use a log splitter valve with an automatic return but on this one I need to wait until an action takes place before I retract the cylinder. I was wondering if I held the same type of valve in the extend position until the action was completed would that work? This is for a tilt table and I need to wait until the material has cleared the table before tilting back to the original position.
Thanks in advance.
   / Hydraulic delay circuit #2
If this will be all mechanical.
Does the table unload via gravity?
What will start the cylinder to extend?
Will the empty table load always be the same?
Any estimate on operating pressure required to raise and hold the empty table?
Pressure required to raise a full table?
Does the tilt return via gravity or does require hydraulic pressure to return?
Depending on the difference in pressures you might be able to use sequence valves.
If electrical operated is an option you could use a time delay relay or some type of sensor to indicate when the table is empty and then retract the cylinder.
   / Hydraulic delay circuit #3
Now there's a process engineer at work. :)
oldnslo - I'd prefer it to be mechanical as an electrical connection is not guaranteed. Not afraid of electrical as I've been doing that in some form or another for over 50 years. Everything is done by hydraulic. Table tilt, table retract etc. Table load will be for the most part the same. There could be some variance but at this time don't know the extent. Pressure will be approx. 2500psi. Don't know how much pressure it's going to take to raise/tilt the table. Approximate weight on table will be ~400 lbs. I'm not real familiar with sequence valves. Just started learning about them.
   / Hydraulic delay circuit #5
RPW,
Sequence valves shift at a preset pressure point. Problem I can see is getting the circuit set up so that at a falling pressure the sequence valve shifts and allows the tilt function to retract or return to the home position.
If this was my system I would start by writing down a sequence of events for how I would I want this to work.
Then I would look at each event and try to determine what I could use to signal the end of that event and start the next event.
Doing this helps me identify what I want to do and what I functions I have to work with.
I agree with mechanical Vs electrical for simplicity and reliability but then I am also an old phart :)
Thanks, I did do a flow chart to help me determine what and when the actions were to take place and all went well until this circuit. I thought about a log splitter valve with auto cycle and was wondering what would happen if the lever was held in the extend function for the duration that it would require to empty the table. I don't think it would be very long but it could be a few seconds, maybe 10 to 20 at most. One thing I thought of would be an additional pressure relief valve to keep from deadheading the circuit.
Mudskipper, great video. Thanks
   / Hydraulic delay circuit #9
From what you described this will be a challenge. I like keeping things as simple as possible and I don't see a simple solution for this.
will think about it some more I am sure.
Oldnslo- Were you able to clear some cobwebs about a delay circuit or do you think an action on then action off might work. What I mean is think of a box passing by a sensor in this case it would be a trip lever and after the box passed it would trip another lever. First lever would extend the cylinder and the second would retract the cylinder. Definitely a brain twister.
2011 New Holland Boomer 90 MFWD Utility Tractor (A55301)
2011 New Holland...
2021 CATERPILLAR D4 LGP CRAWLER DOZER (A51246)
2021 CATERPILLAR...
2024 Cynergy Cargo 2 Enclosed Trailer (A53117)
2024 Cynergy Cargo...
2019 Allmand Night-Lite V-Series 7kW S/A Towable Light Tower (A52377)
2019 Allmand...
2013 CATERPILLAR 312E EXCAVATOR (A51406)
2013 CATERPILLAR...
NEW HOLLAND C362 SKID STEER (A52705)
NEW HOLLAND C362...
