Hydraulic failure on 2610
   / Hydraulic failure on 2610 #1
KennethBrown
Central Texas-Freestone/Donie
Mahindra 5500
Yesterday I was using my dads 2610. I had a round bale on the back (about 1300 pounds) and it had no problem picking it up and moving around. I used the FEL to move a piece of pipe. Again no problems. Loaded it on the trailer and it went to his house (note that the bale was let down on the trailer) which is about 15 minutes away. This morning he raised the bale up and drove off the trailer. No problem there either. He then tried to raise the FEL. It didn't so he set the bale down thinking it might have something to do with it. No change except now neither will raise. The motor doesn't lug down when working the controls. He pulled a line from the FEL and nothing came out when he worked the joystick. So far he's cleaned the screen and looked for stuff out of place. Nothing seems to be working. Any ideas?
   / Hydraulic failure on 2610 #2
Mabe you sheared the pump key
UPDATE: Will he tore it down today. It was infact a shear key. He went to TSC today and picked one up. Hoping to put it back together in the morning and Genny should be running again.
   / Hydraulic failure on 2610 #4
glad to hear u found the problem
Kubota Salt-Spreader (A52384)
Kubota...
STORAGE FEES (A54313)
2011 John Deere 5075M 75HP 4WD Loader Utility Tractor (A52377)
2011 John Deere...
2004 International 3200 Passenger Bus (A51692)
2004 International...
2011 Kubota M5640SU (A50123)
2011 Kubota...
2021 Chevrolet Express 2500 Cargo Van (A51692)
2021 Chevrolet...
