Oil & Fuel Hydraulic fill location
   / Hydraulic fill location #1
Mark in BC
1964 Massey Ferguson 65
I have a 1964 Massey 65 gas. I need to add hydraulic fluid for internals and 3 pt hitch. Where is the fill port?
A pic of the location would be nice if someone could post.
I thought I had found it on top of the trans casing on the left side, beside the hydraulic levers, but when I loosened off the plug, a yellow fluid came out. And do you check fluid level with engine running or not and with hitch raised or lowered.
   / Hydraulic fill location #2
Have a read at the below link but Big Dean said
MF65 has a common reservoir for the Transmission, Hydraulics and Differential. All three are filled at the big plug just to the left of the main transmission shift lever. They all three check with the dipstick in the access plate on the right side of the rear center housing. They hold 8 gallons of oil when completely drained. To get all of the oil out you have to pull both drain plugs.
http://www.ssbtractor.com/wwwboard/view_all.cgi?bd=massey&msg=4896
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50774)
IF YOU BID ON AN...
TOYOTA 7FGCU25 LP SIT DOWN FORKLIFT (A50854)
TOYOTA 7FGCU25 LP...
2016 CATERPILLAR 336FL EXCAVATOR (A51242)
2016 CATERPILLAR...
STORAGE FEES (A51222)
2015 FREIGHTLINER  CASCADIA (INOPERABLE) (A50854)
2015 FREIGHTLINER...
2025 8ft Office Shipping Container (A49346)
2025 8ft Office...
