hydraulic fill on dk35
   / hydraulic fill on dk35 #1
DBABUDDY
i must have been too excited when i picked my tractor up, to hear if the rear end fluid fill is the same as the hydraulic fluid resevoir. can't see anywhere in the manual about hydraulic fluid fill, is it the same as transmission fuild? if not where is the hyd. fill at. thanks
   / hydraulic fill on dk35 #3
Good question...I've got the same thing...
What type of hydraulic/transmission fluid do we use??? It's my understanding the capacity is about 7 gallons. When disposing of this, can it be dumped into the oil recycle or is it not compatible???
   / hydraulic fill on dk35 #4
I just run a tractor hydraulic/transmission oil in my DK 35.
Transmission holds closer to 11 gallons if I remember correctly.
   / hydraulic fill on dk35 #5
</font><font color="blue" class="small">( What type of hydraulic/transmission fluid do we use??? )</font>
Most any universal hydraulic fluid will do. Make sure it has anti foaming agents. Some good ones to use are:
Any brand's 303
Warren, or other brand AW 46 or AW 68
John
PREDATOR  2IN GAS WATER PUMP (A52472)
PREDATOR 2IN GAS...
New/Unused 30ft x 65ft x 15ft Storage Shelter (A51573)
New/Unused 30ft x...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
