Hydraulic fitting leak
   / Hydraulic fitting leak #1
East TX
TYM 574HC
One of the fittings for my front remote (for grapple) is leaking pretty decent. Checked and its screwed on tight. Only leaks when the hose for grapple is connected, so I should take that to mean theres something wrong with the fitting? Ive also seen that there are 2 types of fittings, one has a ball, one has more of a cone shape detent. Is one preferred to the other?
   / Hydraulic fitting leak #2
Could be dirt in the fitting. Brake clean and compressed air clean them out good.
   / Hydraulic fitting leak #3
Is it leaking from the threads? OR is it leaking from the connection of the two couplers?
Is it just a drip or two....or is it a high pressure spray of fluid?
Leaking from inside the connection. Its a pretty steady drip
   / Hydraulic fitting leak #5
O ring pinched or ripped? You can replace them but it can be fiddly. You do have to know what type and size coupling you have. Seems like there are way to many types/sizes in use these days.
1994 Thomas Built SAF-T-LINER (LOW MILES, CUMMINS, ALLISON) (A52748)
1994 Thomas Built...
2013 Mitsubishi Fuso FEC92S 16ft. Reefer Box Truck (A50323)
2013 Mitsubishi...
2015 MACK ELITE LEU633 GARBAGE TRUCK (A51406)
2015 MACK ELITE...
2007 Eager Beaver 35 GLB Lowboy, Tandem Axel (A52384)
2007 Eager Beaver...
