flyngti
I've been holding back on posting until I've had something to say and now it's time. First off, let me sing some praises:
My wife and I finally bought a home on acreage (modest 2 acres) with the intention of turning it into horse property. Thankfully, most of the land had been cleared of really big trees years ago, however we still had lots of work to do. Even though it was a lot of money, we both decided to save our backs and invest in a tractor. After looking at lots of machines, we decided on a JD 2320 with 200CX FEL and bucket forks as it seemed to be just the right size machine for our needs. While we've had to farm out the really big jobs, the 2320 has been a huge help in doing everything from moving gravel to turning the compost bin to pulling small stumps from the ground. Recently, we pulled a bunch of old railroad tie fenceposts out. Because we didn't need them, I placed an ad on Craigslist to give the RR ties away. The people who showed up to get them fully expected to have to heave them into their trucks. Instead, the conversations went like:
them: how do we get these into the truck?
me (with a big grin): hydraulics -- why break your back?
Anyhow, back to the question at hand. This past weekend, my wife was manning the tractor when she noticed a hydraulic leak from the FEL. One of the fittings had come loose and oil was leaking out. I grabbed a rag and a wrench and tightened it back down and the leak stopped. The next day, after lots of loader work, it happened again -- this time it was REALLY loose and oil was pouring out onto the front tire. I again tightened the fitting and the leak stopped. I don't recall which one it was, but it was on different fittings each time. My oil level is now a little low and I stopped by the dealer to pick up some Hygard to bring the level back to normal.
My questions are:
Do these fittings come loose often?
How tight should they be?
After the fittings are tightened again, do you need to do anything to purge any air out of the hydraulic system?
It is enough to just tighten them or should I undo the fitting altogether, put teflon tape on the threads and put the fitting back on?
My questions are:
