Hydraulic flow on L3010
/ Hydraulic flow on L3010 #1
HarleyBob
Puget Sound, WA.
I have a Grand L3010 HST that is rated at 7GPM hydraulic flow.
I am looking at purchasing a mulch spreader for blueberry rows that requires
10gpm but the manufacturer says it will work fine on 7GPM. The hydraulic flow
moves the floor that moves material towards the exit. I have rented similar units
and had the experience that the floor moved too fast and I can adjust ground speed
if my flow was inadequate. The rented unit ran its own hydraulic pump from my pto and I
dont' have any experience running a unit of hydro only (and none available to try).
Has anyone experienced real flow rates for the L3010.
I do know that I have been frustrated at the speed of my rear mounted log splitter
It uses a large 12 ton piston and both the split and return seem slow.
/ Hydraulic flow on L3010 #2
You can measure your flow rate... Open a line and check how many gallons you get in 15 seconds... multiply that by 4 and you will know the gallons per min.
You can get a 3k pressure gauge to see if your pressure is low. KennyV
KIVEL 48" PALLET FORKS 3500 LB CAP (A60430)
KIVEL 48" PALLET...
Carry-On 5'x8' Trailer (A53316)
Carry-On 5'x8'...
John Deere Z994R (A60462)
John Deere Z994R...
207280 (A52708)
207280 (A52708)
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
Year: 2017 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A59231)
Year: 2017 Make...
