Hydraulic hammer as a woodsplitter?
   / Hydraulic hammer as a woodsplitter? #1
jcalla
Triangle, VA
Has anyone tried using a hydraulic hammer as a wood splitter? I think using an asphaly chisel in the hammer might work. Any comments?
JPC
   / Hydraulic hammer as a woodsplitter? #2
The only hydraulic hammers that I have seen or have any experience with are the pile driver type use to drive posts/poles in the ground for fences, jetties, docks, and breakwater barriers. I think that the hammer may move to quick and the stroke won't be long enough to split the wood all the way through. It might work though, you never know until you try. I would look into a Splitfire 3 point hitch wood splitter.
The price is reasonable and the splitter works well.
   / Hydraulic hammer as a woodsplitter? #3
I am amazed i was just thinking the same thing as i have some blocks way to big to lift to the splitter. I am planning on renting one to try so unless someone else has tried and it didnt work i will let you know.
I'm thinking that once you crack it open, especially if your splitting Red Oak, you could just rotate the hammer chisel 90 degrees and spilt it again. It probably would not work as well on wood that doesn't crak open rather easily.
JPC
VA MTN Man, let me know how you make out.
JPC
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2015 MACK ELITE LEU633 GARBAGE TRUCK (A51406)
2015 MACK ELITE...
2023 CATERPILLAR 259D3 SKID STEER (A51246)
2023 CATERPILLAR...
2020 JOHN DEERE 7R210 LOT NUMBER 48 (A53084)
2020 JOHN DEERE...
2021 SMITH CHALLENGER SCM 400 SWEEPER (A51246)
2021 SMITH...
2015 FORD-750 XL SUPER DUTY DUMP TRUCK (A51406)
2015 FORD-750 XL...
