Hydraulic hose cold protection, is it needed?
   / Hydraulic hose cold protection, is it needed? #1
kioti pup
Dillon, MT
2011 Dk45se HST
Hello I live in Montana where its not unusual for the winter weather to reach -40, is it okay to leave my attachment with hydraulic hoses outside and exposed to the cold? If not what should I do to protect it? Thanks! :confused:
   / Hydraulic hose cold protection, is it needed? #2
You don't need to protect it unless it is rubbing on something or too close to something hot. I would just try to get the oil warm before you push things too hard. The cold oil will add lots of backpressure. ISZ
   / Hydraulic hose cold protection, is it needed? #3
Raising and maintaining the 3PH control lever (while engine warming up) to the top extreme will help warm up the hyd oil......the oil will be blowing over relief at the 3PH and add some heat
   / Hydraulic hose cold protection, is it needed? #4
If you absolutely need cold weather hose, Gate has hose with a temp range of -70 to 212 degrees and anything in between.
Product Advisor
This hose is just one of them.
Product ID
46572475
Part #
4G2L X50FT, 85732
Product Description
85732 4G2L X50FT
UPC
072053515930
Category Hierarchy
Automotive Hydraulics -> Hydraulic Hose -> Global G2L PolarFlexョ Hose - SAE 100R2 Type S/AT
Product Images
Product Features
Application
Recommended For High-pressure hydraulic oil lines. Meets or exceeds the requirements of SAE 100R2, ISO1436 2SN R2 and EN 853 2SN. Qualified to Mil-DTL-13531 Type II Class B.
Use High Pressure
Construction
Cover Black, oil and abrasion resistant, thin synthetic rubber (Neoprene - Type A). See Hose Stock Characteristics.
Reinforcement Two braids of high-tensile steel wire.
Tube Black, oil resistant, synthetic rubber (Nitrile - Type C). See Hose Stock Characteristics.
Packaging
Customer Pack 1.0
Packaging T Click here to view Packaging Codes
Standard Pack 1
Specifications
Hose I.D. (in) 1/4
Hose O.D. (in) .59
Minimum Bend Radius (in) 4.0
Temperature
Temperature Range -70ーF to +212ーF (-57ーC to +100ーC). For water emulsions see Temperature Limits Table.
Weight
Weight (Lbs.) 12.93
Working Pressure
Max. Working Pressure 5800
Min. Burst Pressure (psi) 23200
2012 Cadillac CTS Sedan (A53424)
2012 Cadillac CTS...
1996 JLG Commander CM2033 20ft Electric Scissor Lift (A51691)
1996 JLG Commander...
2009 Trail King TK110HDG-523 RGN 66 Ton Tri-Axle Lowboy Trailer (A52377)
2009 Trail King...
BUYER'S PREMIUM INFO (A53084)
BUYER'S PREMIUM...
1838 (A51248)
1838 (A51248)
2012 Ford Escape Limited SUV (A53424)
2012 Ford Escape...
