Hydraulic Leak Help.
   / Hydraulic Leak Help. #1
catvet
Hyde Park, Vermont
Kubota L-39
Had a hose blow out on my Wood's backhoe yesterday. the bucket curler hose. Bummed me out big time as I was working on a big stump and was almost there. Then got the tractor stuck getting out of the area because I was positioned such that I needed to go over the area I was working on. More bummed.
Anyway. I decided the thing to do was to take the hose off and try to get a replacement. Having no knowledge what I was doing it took me about two hours to get it off and lost a lot of hydraulic fluid in the process. Fortunately I had gotten the backhoe off the tractor so the fluid was just from the backhoe.
My big question is, assuming that I can get a replacement. And get it threaded through all the various places this one was, do I need to somehow bleed the air out of the system?
Any help appreciated.
Jerry
   / Hydraulic Leak Help. #2
The double acting cylinder will self bleed after you cycle it a few times.
However, make sure you purchase at least a 2-wire hose that will be rated at 4000 psi or greater. No telling what was on there originally, probably a 1-wire hose.
   / Hydraulic Leak Help. #3
I agree it should bleed out itself. I just replaced a hose on my loader. Obviously you have to add more hydraulic fluid. A lot of places can make that hose. I know JD dealerships can as well as other tractor dealerships. My hose was a pain because I have a grey market tractor with a grey loader and the fittings are metric. I ended up having to take it to a specialty equipment shop.
Thanks for the quick replies. There are a number of places around the area which I think can do the hose. If not I'll make the 1 hour trek to the dealer.
   / Hydraulic Leak Help. #5
Wear glasses. and gloves and long sleeve shirt, pants and protective shoes. Hydro fluid under pressure is bad when it hits the body.
Bob
   / Hydraulic Leak Help. #6
If you are in no hurry you can always go to www.discounthydraulichose.com and order one. Order on monday and you should have it by friday.
   / Hydraulic Leak Help. #7
The more you use your hoe the more hoses you will go through. I quickly found a close shop for emergency hoses and use Discount Hydraulic Hose for the rest. Keep some extra hydraulic oil on standby too.
2018 E-Z Beever M12R Towable Brush Chipper (A51691)
2018 E-Z Beever...
2002 Fleetwood Expedition 36ft Motorhome (A51694)
2002 Fleetwood...
2012 UNVERFERTH 10-INCH FRONT WHEEL SPACER FOR 10 BOLT HUB (A52748)
2012 UNVERFERTH...
2018 Wacker Neuson WL 38 (A52748)
2018 Wacker Neuson...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
