Hydraulic leak on Mahindra
   / Hydraulic leak on Mahindra #1
mnoeltne
Mahindra 26xl Max
Hi,
I've got a hydraulic leak on a Mahindra Max 26 XL HST. It seems to be a leak at the weld in a flanged pipe, exactly as described in this post..
I'm planning to replace it myself, as the nearest Mahindra dealer is 120 miles away since they closed the nearer dealer.
The pipe exits the bottom of the hydraulic pump, travels under the motor, then goes into a block. Given a leak at that point, is there much chance that something else would have been damaged? Or just replace the pipe with the updated version and it's associated O-rings and expect that it will work fine?
#16 on the diagram, along with 17, 21, and 21A
Mark N
   / Hydraulic leak on Mahindra #2
Since it is the pressure line from the pump very little chance anything else is damaged. I would replace the parts and get back to using your tractor
   / Hydraulic leak on Mahindra #3
most likely vibrations that caused the damage.
You might even consider just having it welded. Its been 6 years or so since I had a similar tube on the old Kubota tig welded. a new tube was a small fortune, and it was easy to access, so not too much downside if it didn't work.
OK, thanks! I'll probably just get a new one. It isn't cheap, but not a fortune either. The superseded part number seems to indicate that this may be a redesigned part, so I'm hopeful it will hold up longer than the original.
Mark
2017 John Deere HPX615E Gator 4x4 Utility Cart (A51691)
2017 John Deere...
COOPER LIGHTING CAT. NO. MHEP-22/28-175-MT (A53472)
COOPER LIGHTING...
JOHN DEERE ROW MARKERS - SET OF STACK FOLD 12 ROW 30 INCH ROW MARKERS (A53472)
JOHN DEERE ROW...
UNUSED WOLVERINE TQH-26-02C CLASS II 3 PT HITCH (A51248)
UNUSED WOLVERINE...
(1) UNUSED 7000# DROP AXLE W/ BRAKES (A51247)
(1) UNUSED 7000#...
