hydraulic leak @ transmission housing. Help!
   / hydraulic leak @ transmission housing. Help! #1
carolinadozer
raleigh, nc
John deere 2440
My JD 2440 has a pin hole leak at the transmission housing and a part that I can not identify in my shop manual. It is located behind the brake control valve and below the hydraulic oil fill tube/dipstick. It bolts directy to the housing. I am new to tractor owning so still learning alot. My question. Is there a seal that could be the problem or is there a bigger problem coming?
I would appreciate any advise.
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51692)
2009 Hino 268...
2016 Hino 258 Roll Back (A52384)
2016 Hino 258 Roll...
2011 New Holland Boomer 90 MFWD Utility Tractor (A53472)
2011 New Holland...
John Deere 1018 10ft Rotary Cutter (A51573)
John Deere 1018...
2023 John Deere HD40F Draper Head (A53342)
2023 John Deere...
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A53472)
2-Row Peanut...
