hydraulic Lift arm help
   / hydraulic Lift arm help #1
BrettW
Platinum Member
now in S.C.!!
Yanmar FF205D
Hi,
I have a hydraulic lift arm on my Yanmar that has stopped working. I know that often it is the switch that fails so I replaced it , but still no go. Can anyone give me advise on tracking down the problem? It was working fine and then just stopped. I was using it a lot moving my box blade around doing grading. Sure was nice while it was working.
thanks, Brett W
   / hydraulic Lift arm help #2
It could be the hydraulic oil filter plugged up....... /forums/images/graemlins/frown.gif
   / hydraulic Lift arm help #3
I would say it is probably electrical, that is if your 3 point is still working. I had a Hinomoto 2304 that had one of those that went bad, it was a frayed connection on a toggle switch.
2014 Dodge Charger Sedan (A50324)
2014 Dodge Charger...
8x18 Metal Rack Hay Wagon (A50774)
8x18 Metal Rack...
2006 Capacity TJ7000 (A50120)
2006 Capacity...
2004 John Deere 6215 (A50120)
2004 John Deere...
Guard Rail Pieces (A51692)
Guard Rail Pieces...
2018 Kubota L4701 (A50120)
2018 Kubota L4701...
