hydraulic lift problem
   / hydraulic lift problem #1
djk2450
:confused:i have a 3010S purchased new in 2001. the hydraulic lift has always worked well in lifting various implements (blade, shredder, post hole digger) but for some reason it has started to jerk real bad while lifting. i am trying to use the post hole digger and when i pick the digger up after boring a hole, the lift jerks and bounces real bad on the upward function. there are 2 control levers (draft and position) that control the lift function. the manual is pretty confusing and not very helpful explaining all this. can someone help out and try to explain which lever does what? thanks a lot. Peace and God bless.
   / hydraulic lift problem #2
run your lever(s) as position control.
do your remotes function correctly? power steering? pto engage ok?
does your lift settle quickly when the machine is turned off?.. or 'correct' ( bobbing ) alot when you have a load on it at idle?
correct fluid level, serviced regularly, with filter?
( I used a 3010s for a while... dell in love with that tractor.. almost bought one on consinement at my dealer back before I got my 7610s )
soudnguy
   / hydraulic lift problem #3
My guess is you need a new seal in the cylinder. How many hours on the tractor? Does the post hole digger drop (leak) down by itself when you turn the tractor off?
2011 Autocar ACX64 Xpeditor coe t/a refuse (A52384)
2011 Autocar ACX64...
2008 Chevrolet Express 2500 Ambulance (A51692)
2008 Chevrolet...
2021 JOHN DEERE HX14 (A53084)
2021 JOHN DEERE...
2025 K732 UNUSED Flower Bed (A53117)
2025 K732 UNUSED...
Serrated Tooth Bar (A50123)
Serrated Tooth Bar...
2025 Mower King SSRC (A50123)
2025 Mower King...
