hydraulic line trouble
   / hydraulic line trouble #1
BX25HD
Jackson, OH
Kubota L3800
I wanted to tell you guys about what happened to me today to get your general thoughts. I was bush hogging a small area today, about half an acre. It was just tall grass, no saplings. I was heading back to my house when it felt like my drive pedal (HST) was hard to push. The forward movement of the tractor was also erratic. I stop in front of my garage and got off the tractor to find that it was leaking hydraulic fluid on the right bottom of the tractor. I started to look for any obvious signs of damage, and I could not find anything. I put a few layers of cardboard down on the garage floor and drove the tractor into the garage to continue troubleshooting. I looked for any loose fittings, and found none. I checked the filter to see if it was tight, it was. So I got my oil pan out and started to remove each hydraulic hose one by one. My L3800 has the FEL and BH so there is a supply and return that goes to the back of the tractor. These lines have a fabric jacket around them to help keep them safe. I removed both of those lines and removed their fabric jackets. I found a small crack in one of the lines. It was about 1/4 inch long. I took a good look at the fabric jacket and there was no sign of damage. So this had to be a faulty line, right?
My tractor now has 155 hours and I have had three problems with the BH. It is the BH77. The first problem was that one of the pins in the boom arm snapped. This part was under a recall (or whatever the tractor world calls this) and I should have never received the BH with that pin. The second problem was that when the dealer fixed the broken pin (they gave me a new boom arm as well), the lowest pin did not have a bushing installed on it. So the boom would never come up enough to be locked into position. I had to pick up on the boom to lock and unlock it. They installed the bushing about three months later.
I plan on talking to the dealer tomorrow. I hope they will just give me a new line and a gallon of UDT Premium. I cannot move the tractor at this point. All of this should be covered under warranty, I would hope. I have had this tractor for less than a year.
So anyway, what are your thoughts?
So I went to the dealership today and showed the kid at the service department the hose. First he tells me that he cannot get a replacement part for that. I tell him that I think this should be covered under warranty because the tractor is less than a year old. He tells me that the hose is a "Working part" and would not be covered under warranty. "Working part", what the heck does that mean? I didn't say that, but I wanted to. So I told the kid that I would just call the service manager (their main store is in the next town over) on Monday. Does this sound right to you guys?
   / hydraulic line trouble #3
I belive that your backhoe has a one year warranty. My guess would be that it would be covered.
New Idea Manure Spreader (A50515)
New Idea Manure...
MILLER BIG BLUE 500 PRO TOWABLE WELDER (A52472)
MILLER BIG BLUE...
2012 Chevrolet Cruz Sedan (A50324)
2012 Chevrolet...
2016 Ford Fusion Sedan (A50324)
2016 Ford Fusion...
(INOP) JOHN DEERE 730 CRAWLER TRACTOR (A51243)
(INOP) JOHN DEERE...
