hydraulic manifold block/diverter valve
   / hydraulic manifold block/diverter valve #1
miracle
portsanilac, michigan
ford 2120
I have a ford 2120 diesel 4x4 having a little problem here, iam looking for a picture of the diverter valve that show me what pressure out an pressure return an sump or tank. I have 3 ports on the hydraulic manifold block/diverter valve.
thanks
shawn
   / hydraulic manifold block/diverter valve #2
You can wait for a picture if you choose, or you can figure it out on your own.
What would I do? Lower the lift arms. With the engine OFF, remove the three plugs from the manifold block. Rotate the spool in the manifold to the power beyond position, and move the lever for the three point to the full raise position. Remove the trans/hydraulic filler plug. Now crank the engine a bit, not trying to start, just crank. Oil should exit one of the ports. This is the pump supply port. Then with a rubber tipped air nozzle, hit one of the other two ports with a quick blast of air. If the pressure bleeds off into the case, this is the sump return port. If the lift arms pop up, this is the pressure "return to system" port.
2010 INTERNATIONAL LF627 SLEEPER (A56138)
2010 INTERNATIONAL...
2017 Ford Fusion Sedan (A55853)
2017 Ford Fusion...
2023 DOUBLE DRUM ROLLER (A55745)
2023 DOUBLE DRUM...
Landoll Lowboy Trailer (A55315)
Landoll Lowboy...
33ft Dovetail Flatbed Trailer (A55315)
33ft Dovetail...
2013 XLR THUNDERBOLT 35X14 5TH WHEEL CAMPER (A55745)
2013 XLR...
