quietrangr
- Joined
- Aug 7, 2015
- Messages
- 35
- Location
- Frederic WI
- Tractor
- 1992 230 Timberjack forwarder with Serco loader
I replaced a five valve sectional bank with a three and a two valve monoblocks on a closed center system. The valves work fine, but when I run the machine down the road for 15 or 20 minutes, the hydraulic fluid gets hot enough to make water sizzle on the fittings. I also installed a 1500 pound relief valve before the valve banks. The loader manual calls for 1000 pounds on two of the valves, so I set it there originally, but it was way weak. I then set it up to max 1500, and is still not as strong as before, but it works well enough. I can hear noise at the relief until the oil warms up, then don't hear it anymore. It's a 2000 lb standby pressure system on a 440 C John Deere log skidder. The valve bank controls a Barko 40 log loader. Any ideas?
