Hydraulic oil in crankcase on tc35d
   / Hydraulic oil in crankcase on tc35d #1
deerslayer1971
New Holland TC35d
we replaced the seal on the hydraulic pump then put it together it seemed fine went to use it after 15 minutes the crankcase was full again could something be building pressure and blowing the seal? Hydraulics sounded and worked normal
   / Hydraulic oil in crankcase on tc35d #2
Did you replace both seals in the hydraulic pump or just the outer seal. If the pump blows out, it's most likely caused by the inner seal. The outer seal blowing is just a symptom of the real problem.
2002 VOLVO L150E WHEEL LOADER (A51246)
2002 VOLVO L150E...
2018 KENWORTH T880 DAYCAB (A53843)
2018 KENWORTH T880...
2011 MACK CHU (PINNACLE) (A53843)
2011 MACK CHU...
2017 Ford F-650 Stakebody Flatbed Truck (A53422)
2017 Ford F-650...
2009 International Frazer Bilt X-514 Ambulance (A52377)
2009 International...
